karl1111111111
my immobiliser unit under the passenger seat got flooded now the car will start but the problems are as below can i just replace the immobiliser unit and key fobs with used ones off the same model if they are off the same car already programmed together does any one have any good advice thanks
The fuse blows as soon as put into the fuse box wether ignition is on or off it is the fuse 4th row down 5th fuse from the left
The doors won't unlock on the remote, .
The central locking doesn't operate via the dash switch
The window switches don't work
The front and rear trunks won't unlock via the sill switches
The front trunk won't open via the fuse panel jump point
The battery has good charge - the headlights are fully bright and the convertible top operates at normal
