2001 model with 3.6 engine?
- Thread starter chatts777
You are correct - the 3.6 engine was introduced on the facelift for Model Year 2002 (September 2001 on). If it has the GT1 headlights, it is pre-facelift.
That's not to say it couldn't have had a 3.6 engine retrofitted, but it is a huge amount of work to do this properly. Not only does it need to be fitted with the later DME to control the Variocam Plus, but it also needs lots of re-wiring to retrofit the CAN bus electronics. And then there is the returnless fuel system......the list goes on and on. Most likely it is a misprint, or the seller is misinformed.
Gordon Attar
the '2' before the S is the year.
JagdHamster
