captainsmelly
Well obviously not actually worth the time or the expense, or the constant fettling and tinkering required to keep the carbs balanced and tuned... but ..!
My car's due a timing belt. Swapping a head at the same time isn't much more work. 2nd hand head from ebay, here or breakers a few hundred quid, no need to change valves (doesn't look like you can get any bigger in there anyway) skimmed to raise compression, get it ported and gas flowed by someone sensible and a custom regrind of the cam - no more lift of course - but more sharper profile, more duration and overlap. Make up a manifold to stick a pair of 45's on, change the fuel pump and band it all on. Sell the complete original head, and all the now defunct fuel and air delivery gubbins should recoup most of the cost.
More top end and a lovely howling barking induction system for maybe £1500 net?
Is it worth it though? Is there any power to be released with a less civilized cam and intake system?
As to why I don't just buy a turbo, or more preferably an s2, it mostly comes down to insurance. With all these mods declared I will be paying 3-4 hundred pa. Standard turbo/s2 minimum £1200! Plus the pleasure of owning a one off, a real sleeper that doesn't reveal itself until WOT.
Anyone carried out similar work before? Can't find very much on google, except for americans stuffing small block chevy's into their 944's, and I'm already in the process of chucking one into a capri right now haha
Or should I just not bother?
