geoffbateman
Hello again everybody. I have an oil leak on the engine of my 1987 2.5 Lux. It looks pretty much as if it's the oil cooler cover to engine joint which I believe is quite a common failure. I've seen kits from Porschapart for about £35 and I've read the Haynes manual, the factory 944 manual and had a look at the parts book to see how it all goes together. It looks fairly straightforward, once you can get to it but both the manuals show dismantling on a removed, "dry" engine. I was under the impression that the oil cooler is an oil to water cooler. The question is has anyone on here done the job and if so do I need to drain down the cooling system before I start the job. Is it possible to just remove the cover and replace the gasket without removing the cooler matrix? Any help or comments, as usual greatly appreciated.
