Hi all,
Due to mine cutting out on high boost two years ago, Alasdair very kindly lent me a pair of ECUs which the mechanic fitted and whilst it didn't resolve the issue, he and Alasdair did confirm that these were non-standard, Alasdair by saying they were chipped and the mechanic by the increase in performance. Between times, I was ill for a while and lost interest but now keen to drive the car again, having read the recent topic on boost cut out and the welcome advice contained, found that the airbox? had indeed split and a new one is on order.
Meanwhile, having bought the ECUs, I decided that it would be good to store my original untouched ECUs and get the guy to re-fit the chipped ones whilst he fits the new air box. Before doing so, I'd like to see whose chips they are and find out if they are of dubious origin or ones from one of the well known tuners. I've gently sprung open the tabs but have failed to see how to separate and "hinge" open via the ribbon, the two halves of the upper and lower circuit boards. I think I'm being dense and missing the obvious so would someone be kind enough to describe in very simple terms how to open them so I can see the chips and take any indentifying details off them?
I'm not even sure whether both ECUs each have a chip that is swappable by simply unplugging! I'm not going to extract or touch them, just try to find out whose they are and what to expect in the way of performance increase.
The larger ECU is Bosch 0 261 200 088 Made in Germany 951.618.121.09 TYP 951 MW-02 and the smaller with the tube connection is Bosch 0 227 400 145 Made in Germany 951.618.113.09 TYP KRW-02
Many thanks in stupidity[
Bill
Bill
