Accidentally used my steering lock key to open my driver's door and it worked. I'm not sure how long this has been the case, could be years. I was wondering if anyone else had experienced this issue.
1988 944s I can open driver's door with any key - anyone else had this issue please?
- Thread starter playboxdesign
Thank you for your reply. I bet its been like that for years then. Blimey I travelled abroad with loads of stuff in the boot and never realised it could all have been stolen.
Yes concern I think.
Oh well, I suppose I better get an alarm sorted! May deter someone if they open the car.
peanut
I had to fix the drivers door lock on my 90 944 last week. It had completely seized up with all the brass tangs protruding so the barrel wouldn't turn.
Its surprisingly easy to remove the complete door handle from the door without needing to remove the door card. its just a single phillips screw on the frame of the door.
Once the handle is out of the door there is a single phillips screw holding the lock cylinder in the handle. Takes an hour or so to strip ,clean and reassemble with a little thin oil and refit the handle to the door.
This link might help https://rb.gy/p6ztz5
Thank you, I'll check it out.
peanut
you're welcome !.. It is a bit fiddly and tricky but very doable for the average owner.Thank you, I'll check it out.
It is literally 2x screws to completely remove the handle and the lock cylinder from the handle .
If I get the time I'll do a short video of the whole procedure and post it .
