Hello and welcome. Whereabouts are you? There are many of us in all parts of the UK and quite a few from outside the UK also posting on here: it is a broad community and you are likely to find some fellow enthusiasts nearby.
Paul said:
I'd suggest forgetting trying to get a few cheap horses, and work on actually improving the car so it's closer to the near-perfect car Porsche designed. Check all the service items, many 944s are running on very poor ignition parts for instance. Get the suspension and brakes sorted, and a decent alignment. Lighten it if you are happy to lose some comforts, and enjoy it as a well-balanced car that doesn't need to be driven at license-losing speeds in order to enjoy it.
For an early Lux, I cannot put it any better than Paul has already said it. You won't find any significant level of cheap additional power over and above the factory numbers. What may well made a big difference is spending some money on getting it from wherever it actually is, back up to the factory numbers. Even if it drives smoothly and sounds healthy, it may be quite a bit below optimum performance, and often in such cases it is quite easy to win back the missing horses. So think in terms of renewal of worn and aged components, and good setting-up, especially of ignition and suspension components, rather than replacing things with aftermarket stuff, if you want value for money and a car that puts a smile on your face.
Then if you still want a bit more performance, the lightening route is by far the most cost-effective way of improving the whole performance envelope - acceleration, braking and cornering.
All of which merely repeats what Paul said, so one thing I might add is this:
If you are an experienced hand with old cars then you will know this already, but have a look at the calendar age of your tyres. Whatever make they are, and whatever their tread depth, if they are more than about five or six years old they will have hardened off and be well past their best in terms of ride, handling and road noise. You are better off with new mid-range tyres (e.g. Falken 452) than decade-old premium rubber.
Oh, and I forgot to say it is well known on this forum that the performance of a car varies enormously with its colour. But for some reason there remains considerable controversy about which colours have which performance characteristics
