I have finally found and bought what i believe to be a solid base of a car to get stuck in to, work out any niggles i can find and bring her back to a driving machine like was intended from Porsche!
Drove back home yesterday evening and did just under 200 miles from Stevenage, drove fine with no overheating and no mishaps. I did have a bit of a play in 3rd and seems to be over fuelling quite a lot kicking out some serious black/grey smoke over the 4k mark so i will have to look in to that.
Problems that i have some across so far that i will begin to work on are:
- drivers window seems to of packed up and passenger side is also slow, would eBay be the best bet for finding one? Or am i looking at Porsche for an unused item/s?
- electric mirrors on both sides are lacking in the TLC department, i can't get up and down on the passenger side and drivers side has almost given up lol bless
- play in the steering and juddering from the steering at 60/70> car seems to drift from right to left without the steering wheel being moved so i'm guessing steering column needs looking at/replacing?
- not sure if this is a problem but when flooring it in 5th up to about 80/90 (on a private runway) then letting off the pedal the car seems to stay around those speeds for i'd say almost 5 seconds which was a little worrying, is this something to do with the over run? or over fuelling perhaps? (i've read it could be caused by the sudden increase in vacuum drawing oil vapour from the breather) the car has a K/N air filter too which i wasn't to sure about... and the a manual fan switch which i will be investigating and hopefully putting back to standard.
I will leave it at that for now, sure their are a few more but will try to fix a few at a time and make sure they are done well, i hate getting overcrowded with things.
Anyway she's happily tucked away in my grandads garage for the time being so keeping out of the wet/snow/hail..
Also a few pics and a video i took of the sills to see what people's opinions are on those. I couldn't find any other form of rot on the car, small bits of surface rust in the bottom corners of the front wings and same at the back but i was quite happy with the rest of the underside!
Drivers side:
http://i.imgur.com/AqLy3CG.jpg
http://i.imgur.com/MCb4Odk.jpg
http://i.imgur.com/K9a6WaA.jpg
Passenger side:
http://tinypic.com/r/309uj47/8
Drivers side:
Passenger side:
