1982 - 944 help!!
macky 1313 as you appear to be a newb, look up wheel ofsets in the technical section. The thing to remember with offset is that it is counter-intuitive. More offset will bring the rims further inboard believe it or not, this is so you can adjust the rim so the outside edge does not foul the arch as you increase rim width, The datum point of the mounting flange for hubs with and without ABS is different (side to side the wheel flanges are further apart and as a consequence ABS wheels with a larger offset will sit well inboard, as many posters have said but I just thought a quick expanation of how the offset works would help you.
