18 way seats
DandyDon
Is anyone having problems with 18 way seats not saving seat positions to memory when Comfort Access is activated on a 2025 Boxster GTS 4.0
I presume the car is new from an OPC?
If so, just take it back for them to sort while you have a couple of coffees there?
Hi there DandyDon,
Yes! I do.
I cannot find a written description of how the seat should operate in the Comfort and non-Comfort modes or how to set the system up. The handbook is not helpful.
I have had my new 718 Boxster GTS 4.0 for nearly three weeks, and I cannot figure out how to set the seat up for me in the way I think it should work. I have returned to the Porsche Centre where they could not change the set-up to my liking. They reset the seat system, but it seems even the sales or service personnel do not know how to set it up for me, as much as they tried. I have since set my driving position in setting 1 and on the key. When getting out of the car, I move the seat back almost all the way to the stop, using setting 2 in memory. When I unlock the car, the seat starts moving into my driving position before I can get into the seat. If I untick Comfort mode in the PCM the seat does not move when I unlock and open the door. This allows me to sit down in the car, and I can then touch setting 1 with the door slightly open, and the seat and wheel automatically move forward to my driving position without me holding down the button. I can close the door during the movement of the seat, which is helpful. If I close the door before pressing setting 1, the button has to be kept pressed to allow the seat to go into my driving position. It looks like I will be using it like this.
Any comments?
I have no problems at all - I have Comfort Access unticked and the seat remains in exactly the right position for getting in and out. An undocumented advantage of having longer legs.......🤣
Hi Brian,
In answer .. and my legs and arms are too short :) . When you get in, do you adjust the seat to your driving position by using the button, or is the seat set to your preferred position when you get in and out?
I don't have the "Entry and Drive" option and have left "Comfort Access" unticked. I tried manually moving the seat to its most forward position (wow, it caters for some very small people), then locking the car. I have my preferred seat position saved onto the key I always use (same on button 1). When I unlock the car nothing happens but when I then open the door, the seat moves to my saved position. I then don't have to move it at all to get in or out.
