Whenever I get a new car, I like to deal with the achillies heels straight away, for peace of mind - specifically to the 16v engines I see that as being the cam chain setup.
My question is, in reality does the actual chain often fail or even just stretch enough to cause timing issues or excessive wear? My 944s is on 128k and can find no record for cam chain so will assume it is original. The top slipper pad was replaced in 2006 at 117k.
I plan to replace the bottom slipper and will probably put a new top one in again, even though it has recently been done, for the price and fact I'll be removing tensioner, etc - I feel that I may as well do it again.
I also plan to replace the chain but with the extra labour involved, it makes sense for me to plan it in with a belt change. The belts were last done at 126k in 2011. I don't do many miles so will likely be replacing the belts again in 2015 with probably another 10k miles or so added in that time.
Does that sound sensible, or at this age/mileage is the chain itself likely to be in desperate need of replacement?
