http://www.autocar.co.uk/VideosWallpapers/Videos.aspx?AR=244041&CT=V
Porsche 911 3.8 Turbo
Test date Monday, October 12, 2009 Price as tested TBA
New 911 Turbo is designed to be more entertaining
The new Porsche 911 Turbo. Unveiled in at last month's Frankfurt motor show, the latest evolution of Zuffenhausen's uber coupe/cabriolet has been extensively reworked in a two year program that Porsche's head of passenger car development, August Achleitner, claims has made it an even better and more entertaining car to drive then ever before.
Given the adrenalin inducing appeal of the old 911 Turbo "" a car we described as the best all weather supercar of all time not all that long ago, it is hard to believe such a thing is possible at all. Still, it would be very out of character for Porsche to unleash a new model that didn't, in some little way at least, improve on the one it replaces.
Not that it's reflected in the styling. Tweaks include new titanium-coloured louvers in the front side air ducts, LED daytime driving lamps residing in the place previously taken up by the fog lamps, revised exterior mirrors with a new double arm design, altered tail lamp graphics with LEDs as well as larger tail pipes poking out through the rear valance.
The old but mightily effective multi-point fuel injected 3.6-litre flat six-cylinder petrol engine with its twin variable vane turbochargers, relatively low 9.0:1 compression ratio and split deck design has been resigned to history.
It's replaced by a more powerful direct-injected 3.8-litre version of Porsche's classic flat six-cylinder running newly reworked twin variable vane turbochargers, higher 9.8:1 compression ratio and closed deck architecture which is claimed to boost rigidity. In doing so, peak power climbs from 473bhp to 493bhp at 6000rpm while torque has increased from an already hugely potent 630Nm in the outgoing engine to 650Nm between 1950 and 5000rpm.
Along with the new engine, there's also a new optional gearbox in the form of a new seven-speed PDK gearbox. Fitted to the car we drove, it replaces the Mercedes-Benz produced five speed automatic offered on the old 911 Turbo.
What's it like?
Mind blowing. The bare performance figures - 0-to-62mph in 3.4sec, 0-to-100mph in 7.0sec and 193mph top speed - hint at something very special and better its predecessor in each case. But the way the 911 Turbo goes about its business almost defies conventional road car logic.
You'd likely find a more powerful and faster car over a wide and smooth surfaced race track. But on normal roads "" the sort you and I encounter every day with varying surfaces, odd cambers and all variety of hidden surprises like those served up at the car's launch in Portugal this week, I seriously doubt any rival "" not even a Bugatti Veyron, Ferrari Enzo or Porsche Carrera GT - would come close to matching it for sheer pace or outright dynamic prowess for any length of time.
See the hi-res pictures of the new 911 Turbo
It is the engine, more than anything else, that stands out. Hard as it may be to image given the sort of power it develops, there is no discernable turbo lag at all. Owing to the increased capacity and higher compression ratio, Porsche has actually decided to dial back boost pressure a touch, from a previous 1.0 to a nominal 0.8 bar, in the interests of added driveability. The result is even keener throttle response and a level of flexibility you really have to experience to believe.
The weight has been trimmed by 25kg in models with the new dual clutch gearbox over those running the old automatic to an impressive 1595kg, giving it a power-to-weight ratio of 309bhp/tonne.
When the road is straight, you're treated to typically solid and high speed stability, albeit with some characteristic bobbing at the front end as lift forces begin the build. More remarkable that this, however, is the speed at which the dual clutch gearbox manages to pick off the gears without any interruption in acceleration despite having to cope with all that torque.
The steering wheel mounted paddles are nicely weighted, positive in action and enhanced by a Sport Plus function, which lights up on the left-hand spoke of the steering wheel, to signal a remapping of the throttle for an even more aggressive throttle response. As well as making it faster, another one of Porsche's primary aims with the new 911 Turbo was to make it more entertaining.
It's certainly gained in terms of overall agility, feeling less reliant upon the four wheel drive system for grip and more accommodating to sudden changes in direction. With the optional torque vectoring automatically braking the inside rear wheel, there's a new found willingness upon turn in as well as a noticeable increase in the amount of speed you can confidently carry through corners. On normal roads the handling is virtually vice-free, with so much grip you'll never feel the need to turn off the ESP.
However, as devastatingly good as the 911 Turbo is, it can sometimes come across as lacking a certain something. I'm opposed to calling it clinical , but in certain respects that's exactly what it is, if only because of the way it is able to conquer every thing you throw at it with such crushing authority.
While superbly damped and wonderfully direct, the speed sensitive variable rate steering is also a little short on ultimate feel. Compared to lesser, rear wheel drive versions of the 911, there's clearly less being communicated from the front end.
Should I buy one?
There are more spectacular looking, faster and better sounding supercars for the money. But as an everyday proposition the new 911 Turbo is just about beyond comparison.
Greg Kable
First drive data
How much?
Price as tested TBA
Price as tested TBA
How fast?
0-62 mph 3.4 sec
Max speed 194 mph
How big?
Weight no data
How thirsty?
Combined 24.1 mpg
CO2 emissions no data
Engine
Layout no data
Max power 493 bhp
Max torque no data
What's it like?
Should I buy one?
Greg Kable
First drive data
How much?
Price as tested TBA
Price as tested TBA
How fast?
0-62 mph 3.4 sec
Max speed 194 mph
How big?
Weight no data
How thirsty?
Combined 24.1 mpg
Engine
Layout no data
Max power 493 bhp
Max torque no data
