Front windscreen pillar cover removal
Johnsands64
Guest of the Club
Hi Everyone, I am looking to remove a dashcam from my 911 996 registered in 2000 and the cable goes behind a pillar(see photo), how do I remove the cover so I can get the cable out? Many Thanks for all of your help.
I extracted this from a DIY in the Technical Articles section. Hope it helps.
On my Cayman the A pillar could be taken off by pulling away the door seal and getting a trim removal tool under the edge. The trim could then be popped off.
Carefully start at the edge and gently pull the cover away from the pillar to release the clips, working gradually along its length.
