Oil change on 987 - which oil to choose?
richardm
Good afternoon all,
I am wanting to change the oil and filter on my 2006 987, and I know there has been discussion on preferred oil types,
but cannot see anything recently. My local independent has suggested 'Liqui Moli' and to go for motorsport grade.
I know oil is very expensive nowadays, but then again it is a good investment in looking after Stuttgart's finest!!
I'm not doing huge mileage - about 5k per year, and not into motorsport, but just want to look after the engine.
Any comments on this make, or any other preferences would be much appreciated....
There are so many choices, but using 0W40 or 5W40 fully synthetic is a must as a starting point.
Liqui Moli is among many top oils but may not be so easy to find at good price and the Boxster takes 8L of oil so price is a factor!
You can't go wrong with Mobil 1, as it is the Porsche oil of choice but following the recommendation of my Indy a few years back, I use Mobil Super 3000 X1 5W40 as it is recommended by Porsche and a sensible price.
I'd recommend a visit to Opie Oils website as they have loads of suitable oils and the Data Sheets are available for them too, so you can check if they're Porsche approved. They also offer a discount for PCGB members on their already sensible prices!
Good luck with your search!
I would expect so - A40 is for petrol engines. For diesels like the Cayenne etc. the Porsche approval is C30.
The Opie Oils site provides all the A40 specs if you search for them:
[ul][*]Porsche A40 Engine Oil[/ul]
Hi I am looking for advice on oil for an oil change, Boxster 2009 987.2, heard a bit of information on line about, liquid moly and others. The last post I can see was 2022, so has much changed since then, are there better quality oils other then Mobil 1 to consider? No track use, about 5k a year, interested in the best option and think spending extra might be worthwhile! Any comments and experience of smoother revving, better performance appreciated. Thanks in advance, Kirk.
Previously used Mobil 1 and for last 2 years been using Shell Helix Ultra 5W40 on relatives 987 and wife's 986 and both running beautifully across the board.
It comes in 5 litre cans and found Arnold Clark (direct) are the cheapest.
Hi Kirk,
The link to Opie Oils above is still active and valid, and shows a number of options meeting Porsche’s A40 spec. Mobil 1 0W-40 is still Porsche’s recommended oil, although 5W-40 quite often is used on higher mileage cars.
The Millers oils are very good. My local VAG tuner is a fan and used it when servicing my ancient Mk5 Golf GTi when I had it. Their Performance oil should be a good fit.
Talk to Opie Oils for more detailed advice.
Good afternoon all,
If you speak to Julian at Hartech, he’ll point you towards Millers 10/50 nanodrive. I used it in my 2005 3.2 and it’s fine.
