OK what was as I thought a quick job is proving not to be the case..... started out with the task of changing the rear light gaskets only to find I need to remove the rear lights ..... then the fixings were corroded so had to drill them out .... it goes on.
So decided to remove the rear bumper so would appreciate a step by step task list of how to do this including how the disconnect the number plate harness and rear fogs so I can remove the rear light loom. The rear lights are already out of the car.
