Hi. Does anybody have a wiring diagram for electric windows on a 1983 911 sc?
Hi Joe. Do you know where the wires are located between the windows i.e. behind the dash or under the bonnet?
malcolm Davies said:
Thanks Joe. Have you had issues with windows not opening?
Only really with the switches. The contacts on mine needed cleaning up so I took the switch apart to do it. I was in the door anyway as I was adjusting the height and angle of the window. It was all to do with getting the fit right between the Targa top and the window.
I didn’t need to trace the wires back because I was getting the correct voltage at the switch.
I would check there first
regards Joe
Ok that's useful; i didn't realize you could take them apart. My switch seems to work one way only.
