50% Off All Filters - Today Only
mcgc0
I use Eurocarparts quite a bit for all our cars. Today I recieved the 50% discount code for all filters (FLASH50). Genuine oil filters still a better deal direct from your OPC. Those needing to replace their 968 particle/pollen cabin filters can make quite a saving - today for £17.50 (down from £35 each!) You'll need two of course. These are normally silly money from anywhere.
Alternatively, I use high grade and high micropore impregnated aquarium filter foam - bought as correct 25mm thickness and as a single large piece which I cut to size. Works perfectly.
