Cannot open drivers door from outside - 2004 996 C4S
fcd911
After unlocking my car, either by key fob button or key in door lock I lift the handle but cannot open the door, the door glass drops but nothing else happens. The passenger door opens and I can reach across and open the drivers door from inside using the internal handle.
Before I start removing the door card etc I would appricate any advice or indication of a possible cause.
Thanks in advance
John
Hi John,
I had a similar problem on my Cayman S, took it to my local OPC who quickly sorted it out by spraying a lubricate in the mechanism, so now once a year I spray both door locks on my Porsches and the problem has never raised its head again. Hope this helps its worth a try first ?
regards
Pete
Hello Andy / Pete
Thank you for the quick responses, looks fiddly but straightfoward to resolve.
Regard
John
Just try and push the door really hard shut, it maybe the latch/micro switch hasnt engaged
