Has it been tested on PIWIS or Durametric and if so what were the results.
Has the correct sensor been replaced? Bank 1 is not the same side on a Cayman v 911 and PIWIS and Durametric think in 911 terms.
Have the exhaust gaskets been checked, if damaged these can cause issues as described.
I went through a similar issue, Engine CEL, Cruise, PSM and Stop/Start all failed. My issue was an intermittent Lambda sensor failure (check the voltage) and that was replaced. But the exhaust manifolds that had been taken off were not re-fitted properly so air was getting in causing almost the same set of error messages.
