2017 Caynnne GTS high idle speed with a little shaking
yunfei306
Hi everyon,
i bought a brand new caynnes GTS last October. After 3 months ownershi, I noticed that the idle speed goes up 1 marker occassionaly (normally it's in 4th marker)when the car stop and the idle speed is in the higher position till I switch off the engine. Wait for while the idle speed backs to normal position when I switch the engine back on. This happens about 2 or 3 times a week. I also noticed that idle pointer has a little shaking when the idle speed is in both normal and higher position.
I sent my car to my local dealer once, I was told that there was no error fault after they run the diagno test and they reset the compute. After that my car was fine for while, but recently it happens agai.
Do you think it is normal? Do I need to send it ba to dealer to check again?
many thanks in advance
