I took the boxster for a drive today. I hadn't used the PASM for around a month. I tried to use but the light won't come on.
I checked the fuse box, all fine. No warning on dash. No fault codes using my Bluetooth OBD2.
I'm not so sure if the car is in hard suspension mode or not.
Is it possible that it can be affected by the snow weather last week? Also yesterday I washed the car, I tried to sprinkle some water underneath to clean any salt residues and put water with the hose inside the wheel arches to wash them too. Are there any connections that might be affected there?
