Oil checking advice required
Steelback
Steelback Guest of the Club
2018/03/03 22:25:32 (permalink)
Good evening all after a little bit of newbie advice please. Do you check your oil level from cold or after the engine has been warmed and left to settle ?
Buckinghamshire
2007 Cayman 987
Agate Grey
21 Replies Related Threads
    adrian55
    • Status: online
    adrian55 PCGB Member
    Re: Oil checking advice required 2018/03/04 07:15:35 (permalink)
    I always check mine from cold- before i start it. Still miss a dipstick !!
    Ray
    • Status: online
    Ray PCGB Member
    Re: Oil checking advice required 2018/03/04 08:32:19 (permalink)
    I have always checked my oil from cold on a level area. I would think most of the drivers on the site will do that.
    Yes Adrian, I too miss the dip stick check.
    As an aside there are some exceptions to the rule (not Porsche). I have a Mitsubishi Pajero 2.8td SWB and on the auto g/box dip stick there are two level marks, one cold and one hot.
    post edited by Ray - 2018/03/04 08:33:21
    AndrewT
    AndrewT PCGB Member
    Re: Oil checking advice required 2018/03/04 08:52:14 (permalink)
    Like Ray I've always checked the oil from cold with the car on a level area but with the electronic oil level indicator on the 987.2 it can only be checked with the engine idling and at normal operating temperature (at least 60 deg C). What advice is given in the handbook?
    tscaptain
    • Status: online
    tscaptain PCGB Member
    Re: Oil checking advice required 2018/03/04 08:58:20 (permalink)
    Did the oil checking change between Gen 1 and Gen 2 cars?  I.e anytime with the engine off for Gen 1 and above 60C oil temp with engine idling for Gen 2.  It did with the 997.1 v 997.2
    R15 Joint RO
    SWMBO 997 GTS Platinum silver
    Following: @PCGB_997
    AndrewT
    AndrewT PCGB Member
    Re: Oil checking advice required 2018/03/04 11:51:24 (permalink)
    I believe that it did change Alan, I once had a brief look at someones Gen 1 Cayman and noticed that they could check the oil level with just the ignition on whereas my Gen 2 needed to be running and up to temperature - the amount of time to get a measurement varies and there's a countdown in seconds displayed to indicate when the reading will be taken, I find it gives me something to look at while waiting at traffic lights, sometimes they go green too soon!
    am1985uk
    am1985uk PCGB Member
    Re: Oil checking advice required 2018/03/04 12:20:59 (permalink)
    Presumably the more complicated oil pumping and scavenging arrangements on the Gen 2 engine necessitated the change in procedure.
    2014 Cayman S
    West Sussex (R23)
    Ray
    • Status: online
    Ray PCGB Member
    Re: Oil checking advice required 2018/03/04 12:25:15 (permalink)
    The handbook (page 75) on my 981 reads: Prerequisites for the oil-level gauge:
    1, Park the vehicle on a level surface
    2, Switch off engine, which is now at operating temperature.
    3, Wait for approx, 1 minute.
    4, Select the Oil Measurement Function on the multi-function display.
    Just a bit of useless info but the 1984 Porsche 911 3.2 which I ran the oil level was read when the car was at operating temp and with the engine running. So there is some variations on oil level checking.
    Ray
    • Status: online
    Ray PCGB Member
    tscaptain
    • Status: online
    Re: Oil checking advice required 2018/03/04 13:02:20 (permalink)
    Indeed, but the OP has a 987.1.  Curious that it changed from the 987.2 to the 981 though although, having just looked, it also changed from engine running to engine stopped (and hot) from the 997.2 to the 991.1?
    R15 Joint RO
    AndrewT
    AndrewT PCGB Member
    Re: Oil checking advice required 2018/03/04 14:10:03 (permalink)
    Steelback
    Even the "Cayman 987 2007-2008 Vehicle Quick Reference" does not state whether it must be done cold or warm https://www.porscheclubgb.com/legacy/clientftp/Register/996/misc/cayman/cayman07-08qrg.pdf. Perhaps it doesn't matter, is there a difference in the waiting time countdown dependent on whether the engine is cold or warm and does it make any difference to the reading you get?
    Attached Image(s)
    Ray
    • Status: online
    Ray PCGB Member
    Re: Oil checking advice required 2018/03/04 15:22:48 (permalink)
    tscaptain
    This is all getting rather confusing to say the least. Me thinks I shall just stick with the method of my own vehicle. As we said earlier the dip stick was an easy method but now we are getting more electronically minded in engine design then I suppose this is the future.
    Ray
    BJ Innes
    BJ Innes PCGB Member
    Re: Oil checking advice required 2018/03/04 16:09:39 (permalink)
    On my 718 CS, the hand book says under certain circumstances the engine oil level cannot be displayed.
    Causes include:
    Engine is cold.
    Vehicle parked following full throttle operation at high engine speeds. (e.g. after hot laps on a track day).
    Engine oil temperature too high.
    Open rear luggage compartment lid.
    All of these I have experienced by trial and error. A dipstick was a lot simpler.
    Brian
    Nairnshire,
    Highlands
    Previous:
    2007 Cayman 987.1 2.7 Manual.
    2010 Cayman S 987.2 Manual
    2012 Cayman R Manual
    2019 718 Cayman S PDK
    Current:
    2015 Abarth 595 Competizione 180bhp Manual
    718 Cayman GTS PDK
    tscaptain
    • Status: online
    Re: Oil checking advice required 2018/03/04 16:53:01 (permalink)
    Ray
    tscaptain
    Ray
    Not really confusing.  The different models have different methods, all of which are detailed in the appropriate owner's manual!  The OP, presumably, was seeking advice from owners with the same model as himself.
    R15 Joint RO
    Steelback
    Re: Oil checking advice required 2018/03/04 22:07:00 (permalink)
    Thanks guys - oh for the want of a dipstick
    Buckinghamshire
    2007 Cayman 987
    Agate Grey
    JMR
    JMR PCGB Member
    Re: Oil checking advice required 2018/03/04 23:23:44 (permalink)
    Steelback
    On my 987.1 Boxster I can turn the key and read the oil level from cold.
    When I've been driving and I try to check the oil level, a countdown timer appears, and it could be anything before the car will let you check.
    I've had counting down from 55 minutes sometimes.
    Sometimes its 6 or 10.
    I tend to check it cold and see where the level is, and I check it when up to temp too.
    For example I filled up with fuel, went in the garage, bought some stuff, paid for the fuel, went back outside, got in car and it allowed me to get the oil level straight away.
    If its one bar off full I'm reasonably content, it's never gone below.
    I think I've put < 1/2 litre of oil in during 6k miles.
    AndrewT
    AndrewT PCGB Member
    Re: Oil checking advice required 2018/03/05 08:16:21 (permalink)
    Thanks JMR!
    From what you've said it sounds as though the 987.1 oil level is best checked with the engine cold, or at least below a certain temperature, and that the countdown operates while the engine temperature is decreasing until the correct measuring conditions have been reached.
    It always seemed a bit odd to me that you cannot check the oil level in a 987.2 until operating temperature has been reached, after all what would happen if there was little or no oil in the engine (apart from it seizing!)?
    tiskev
    tiskev PCGB Member
    Re: Oil checking advice required 2018/03/05 08:57:49 (permalink)
    What is the reasoning behind Porsche doing away with Dip Sticks ?
    tscaptain
    • Status: online
    Re: Oil checking advice required 2018/03/05 10:04:08 (permalink)
    It's all the consumer's fault, apparently....
    Why no dipstick
    R15 Joint RO
    Motorhead
    • Status: online
    Motorhead PCGB Member
    Re: Oil checking advice required 2018/03/05 10:12:58 (permalink)
    Kevin,
    Apart from those of us old enough to know the function of dip-stick, I doubt that many drivers these days are interested in opening the the bonnet for any reason, let alone to check the oil level, relying on the electronic sensors to take care of things.
    As Andrew has pointed out, it does seem bit odd that you cannot check the oil level in a 987.2 until operating temperature has been reached but I would assume that you'd get a warning if the level actually fell below the minimum level on the 3-bar display. Even then I'd expect there to be a margin of safety.
    987.2 Cayman S
    North Bedfordshire
    PCGB R10 and R24
    Porsche
    Lockton
    Silverstone Auctions
    Pirelli
    Pirelli
    Oracle Finance
    Archant Dialogue
    HFMC Wealth
    Cornbury House
    Cotswold Business Village
    London Road
    Moreton-in-Marsh
    Gloucestershire  GL56 0JQ
    Call us: 01608 652 911
