Buzzing Window Switch Panel
JAW911
Has anyone suffered with this noise? Initially thought it was the speaker but if you hold the switch panel down, when the bass notes buzz, the buzzing stops. Extended warranty won't cover this apparently. Anyone managed to correct it themselves?
Not sure if the buzz I had 3 weks ago is the same as yours... The small panel behind where the keyless key fits and the lighting rotary switch started rattling.
I took it into my OPC in Bristol who took the panel out and there was a small wiring loom that had become undone or unstuck. I waited while they sorted it, under warranty. Took them a few hours but they bought me lunch.
It's ok now.
Good luck with your buzz.
Simon
Thanks Simon. No it is the door switch set for the windows and mirrors that rattled although my OPC told me that by holding down the switch the sound will stop, that is not always the case. Not covered by extended warranty apparently. Was your warranty new or extended?
