MOT cost.
mark m3 cab
FAIL
Mileage23,751 miles
MOT test number5087 4512 5146
Test locationunavailable until further notice
Reason(s) for failure
  • Windscreen washer provides insufficient washer liquid (8.2.3)
  • Offside Rear position lamp(s) not working (1.1.A.3b)
  • Offside Stop lamp not working (1.2.1b)
  • Nearside Headlamp aim too high (1.8)
  • Offside Headlamp aim too high and too far to the left. (1.8)
  • Registration plate lamp not working (1.1.C.1d)
  • Direction indicators not working (1.4.A.2c)
  • Steering column top bearing excessively worn (2.1.2c)
  • Drivers seat insecure (6.2.A.1)
  • Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
  • Offside Rear Drive shaft which forms part of the suspension coupling gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.4.G.4e)
  • Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
  • Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
  • Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Offside front brake binding (3.7.B.1)Advisory notice item(s)
  • Offside Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
  • Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
  • front and rear inner wings and floor corroded
  • vehicle in poor condition
  • Hi all , thinking about buying a 912 white 1967 LHD ,failed MOT in 2015 with the above problems .The car has not been used since 2012 but starts and runs .
  • What would it cost to have the above work done and what is the car worth without a new mot.
    Many thanks
