Targa Noise
WNX700H
OK Collected my car yesterday drove it home but at speeds anything above 40mph the targa makes an increasing noise , sounds like its coming from the front edge to the left of the rr view mirror as you sit in the car.
Have not had the roof panel out yet but any order in which to approach this. I was aware of the noise before purchase
Sounds like the top not seated properly at the front...should be able to see this. Also make sure the closing mechanism is making a tight seal on both sides. It’s not an uncommon problem
Graham
Yes the leading edge of the targa does sit above the windscreen frame in certain areas across the front and that's exactly where the noise eminates from. So how do you adjust this?
David
