Pre MoT inspection identified play in n/s front strut, and worn bushes. Also the car rolls a lot on track days. So I'm starting to look around:
Worried by reports on here that OEM Porsche shocks (Fichtel & Sachs?) are old stock and prone to early failure, so I like the idea of Bilstein B6, except that it's an insert and requires the old strut to be butchered to accept it...not sure my indie is keen on that.
Koni are also inserts, so what are the other options? If we're doing the rears too, the parts cost alone is approaching £1000, and if I can find someone to fit inserts the bench time will increase labour cost?
Which leaves us with KW V3 inc. new front springs and rear coilovers...an attractive prospect at £1850.
So does the KW package fit straight on? And is the lower ride height an issue?
I'd appreciate the benefit of your experience on this, please.
