Porsche Cars Remanufactured 924 Parts - 17 More Added for 2017
PaulHere
[h1]Porsche Cars Remanufactured 924 Parts - 17 More Added for 2017[/h1][FONT=times new roman, serif"]The Porsche Cars website carries a Classic Product News section that lists remanufactured Genuine parts, this file is dated February 2017 and contain parts for all 924 variants. I have extracted (the best I can) the relevant parts for our cars from the list - please refer to a Porsche Centre or specialist before ordering parts for your car - this list is for information only[FONT=verdana,geneva"]
[FONT=times new roman, serif"][FONT=times new roman, serif"]February 2017[FONT=verdana,geneva"][FONT=verdana,geneva"]
Engine
137. 92810317303 Connecting-rod bolt 924 S (1986–1988) 928 (1978–1995) 944 (1982–1991) 968 (1992–1995)
138. 99903404001 Hexagon nut 924 (1976–1985) 924 Turbo (1979–1982)
139. 93110220200 Hexagon head bolt M12x1.5x18 924 Turbo (1981–1982)
140. N 0102407 Hexagon head bolt M8x20 924 (1976–1985) 924S (1986–1988) 928S (1983–1984) 944 (1982–1985)
141. 90008302108 Hexagon head bolt M12x1.5x20 924 Turbo (1979–1982)
142. N 0401101 Hexagon head bolt M12x1.5x22924 (1976–1985)
143. 99911324740 Radial shaft sealing ring 924 Turbo (1979–1982) with transmission type G31.01924 Carrera GT (1981) with transmission type G31.03
144. 171412135 Protective cover for vibration damper 924 (1976–1985) 924 S (1986–1988) 924 Turbo (1979–1982) 944 (1982–1985) 944/2 (1986)
145. 477611017 Brake master cylinder 924 (1980)
146. 477611017A Brake master cylinder 924 (1981–1985) 924 Turbo (1981–1982)
147. 211609601B Bearing pin 924 (1976–1985) 924 Turbo (1979–1982)
148. 477867367A A-pillar door frame piping 1,700mm 924 (1976–1985) 924 Turbo (1979–1982) 944 (1982–1985) 944 Turbo (1985)
149. 477867367B B-pillar door frame piping 820mm 924 (1976–1985) 924 Turbo (1979–1982) 944 (1982–1985) 944 Turbo (1985)
150. WKD48051000 Vehicle document folder 911G (1974–1989) 928 (1978–1982) 928S (1981–1986) 928 S4 (1987–1989) 914 (1974–1976) 924 (1976–1988) 944 (1982–1985) 944/2 (1986–1989) 944 Turbo (1985–1989) 944S (1987–1988) 944S2 (1989)
151. WKD48551000 Vehicle document folder 914 (1974–1976) 924 (1976–1988) 928 (1978–1982) 928 S (1981–1986) 928 S4 (1987–1989) 944 (1982–1985) 944/2 (1986–1989) 944 Turbo (1985–1989) 944 S (1987–1988) 911 G (1974–1989) 959 (1987–1988)
152. PCG91410000 Light bulb and fuse set 914/924 914 (1970–1976) 924 (1976–1988)
153. PCG70192400 Licence plate frame "924" for all 924 models
As a very new owner - not even picked up the car yet ! [ Black 924S Le Mans ] - the one job I want to do is sort out the cracked dash. I know it's a problem loads of owners have faced but are any new dash's available or is it just '' hunt the best second hand one '' ??
Steve
The only person remanufacturing dashboards that I am aware of is werk924 https://translate.google.co.uk/translate?hl=en&sl=de&u=http://www.werk924.com/&prev=search he makes them in LHD and RHD and needs your old one I think. They are only listed for 924 up to 1982, probably because there was a slight change in texture on the later ones. Several 924 owners undertaking full restorations have used them. No reason I can see why they can't be used on later models.
First time on Forum - Hello !
I own a 1988 924s and just had (my first) MOT and passed with flying colours. However, during the inspection, it was noted the fuel pipe from the fuel pump to fuel filter needs replacing.
Any idea where I can obtain one, please
Phil
