wheel spacers
  • Status: online
Guest Guest of the Club
2017/06/16 08:52:34 (permalink)
wheel spacers
hi im changing my wheels on my cayman s 3.4 2006 from 18 inch to 17 inch but they it the calippers can anybody tell me what size spacer to use
4 Replies Related Threads
    MrDemon
    MrDemon PCGB Member
    Re: wheel spacers 2017/06/16 09:53:10 (permalink)
    impossible to answer  that sorry to say.
    Not sure I would want to run 17" on a 3.4 myself, 18 is a great size/performance for the gen 1 car.
    if the calipers hit the rim then spacers won't help you.
    if they hit the spokes when the wheels size has nothing to do with it.
    Radio ? NONE.
    Cup Holder? NONE
    Air Condidioning? DITTO
    A pure roadster. Reduced to the essentials
    Still the fastest...
    Buddy
    Buddy PCGB Member
    Re: wheel spacers 2017/07/14 10:22:52 (permalink)
    I know that some carry a spacesaver spare wheel of 17" diameter but as for spacers I'm unsure since the spare wheels are of different width and offset to the standard wheels either 18 or 19" in fact very narrow so may clear the calliper only due to this, I know that some racers use smaller wheels.
    The Spare wheel used in an earlier article on the technical articles section was a 185/60/17 spacesaver tyre on a 987 Cayman, I couldn't find if it was a Cayman S which has the larger brakes but the wheel used had a 996 part number.
    post edited by Buddy - 2017/07/14 11:04:39
    Kevan
    Cayman Register Secretary
    Location South Derbyshire
    PCGB R8
    Kieron
    Kieron Guest of the Club
    Re: wheel spacers 2017/07/18 14:44:06 (permalink)
    I'm thinking of fitting 235 x45 x17 instead of 235 x50x17 on the rear. I 've worked out that the speedo will over read by about 2mph at 70mph, but are there any fitting or body/suspension clearance issues?
    Buddy
    Buddy PCGB Member
    Re: wheel spacers 2017/07/23 23:13:43 (permalink)
    Since the change according to the measurements you give only effect the diameter there will be no issues, in the figures the width and wheel diameter are identical and only the aspect ratio is effected.
    Probability is that given that Speedo's are normally calibrated to slightly fast by 2-3 mph then at first the reading will be expected to be accurate but this will later read slower due to wear and so you should expect that the speedo will be more inaccurate later, take greater care regarding your speed, for track work it does give some advantages due to the lower sidewalls, the lower gearing gives slightly improved acceleration etc
    post edited by Buddy - 2017/07/23 23:27:55
    Kevan
    PCGB R8
    Quick Reply: (Open Full Version)
      Enter the random characters shown
    Submit Post
    © 2017 APG vNext Commercial Version 4.6
    Porsche
    Lockton
    Silverstone Auctions
    Swissvax
    Pirelli
    Oracle Finance
    Archant Dialogue
    Pirelli
    Cornbury House
    Cotswold Business Village
    London Road
    Moreton-in-Marsh
    Gloucestershire  GL56 0JQ
    Call us: 01608 652 911
