Disc Brakes and Pads
Buddy
Buddy PCGB Member
2015/05/24 11:15:35 (permalink)
A useful bit of info was garnered on the recent visit to JAZ Porsche St Albans is that the original Brake Discs on the 987 Gen1 are manufactured by Sebro and according to Steve at JAZ are indistinguishable from Original Porsche apart from the Porsche Part marking and their kite mark which he didn't actually say where the marks are but coatings etc are as Porsche, Original Brake Pads are Textar.
Disc Wear
Cayman is:
Front - Original thickness = 24mm Minimum = 22mm
Rear - Original thickness = 20mm Minimum = 18mm
Cayman S is:
Front - Original thickness = 28mm Minimum = 26mm    Pads 17,0mm ( Textar OEM )
Rear - Original thickness = 24mm Minimum = 22mm     Pads 15,5mm ( Textar OEM )
post edited by Buddy - 2017/08/21 12:04:59
Kevan
Cayman Register Secretary
Location South Derbyshire
PCGB R8
5 Replies Related Threads
    spyderman
    spyderman Guest of the Club
    RE: Disc Brakes and Pads 2015/05/24 14:34:03 (permalink)
    Pretty good value through EuroCarParts.com too - especially when you get one of their discount codes. We ran the Sebro discs on my race car for three seasons without any problems - so long as you replace them when they start to crack around the cross drill holes.
    Chris.
    You don't stop having fun when you get old - you get old when you stop having fun.
    Boxster S 550 Spyder Anniversary
    gmcraib
    gmcraib PCGB Member
    Re: RE: Disc Brakes and Pads 2018/12/04 17:50:36 (permalink)
    Do you have any data for PCCB?
    2016 981 GT4 Cayman Sapphire Blue
    2007 987 S Cayman Cobalt Blue - Gone but not forgotten
    Region 2, Aberdeenshire
    Motorhead
    Motorhead PCGB Member
    Re: RE: Disc Brakes and Pads 2019/08/19 09:14:24 (permalink)
    Posted by T911UK on another thread:
    "Textar do indeed supply pads to Porsche, so these will be the same, discs however are not supplied by Sebro, they do supply Porsche some discs for very rare and early air cooled 911. SHW supply discs to Porsche and only to Porsche, you cant get them outside OPC."
    For reference, I believe that he is associated with Type 911, a Porsche parts supplier.
    987.2 Cayman S
    North Beds (R10 & R24)
    T911UK
    • Status: online
    T911UK Guest of the Club
    Re: RE: Disc Brakes and Pads 2019/08/19 10:32:05 (permalink)
    I am indeed, not hiding anything!
    www.type911.co.uk
    993 Turbo
    911 SC Targa - Minted
    Cayenne Turbo S
    Boxster 987 2.7
    mjhamilton
    mjhamilton PCGB Member
    Re: RE: Disc Brakes and Pads 2019/10/28 16:22:35 (permalink)
    that is very interesting
    I replaced all the discs and pads on my 2011 Cayman last month and the discs were Sebro and the pads were Textar - according to the service history this is what OPC fitted a few years back
    I purchased the identical items from ECP using their infamous discount code on the advice of the Indi I use and they were spot on - I checked each item as I removed and checked against new and all the part numbers and marking were exactly the same - the only minor different was that the rear pads had switched to horseshoe wear indicators from pin type
    post edited by mjhamilton - 2019/10/28 16:24:41
    2011 Cayman S 987.2 PDK Black Edition #179 or 500
