Cayman S 2007 Fuse Listing
Buddy
Buddy PCGB Member
2012/09/19 08:33:23 (permalink)
Here I think is a useful fuse list for the Cayman for the subforum, I have taken off references to other models since Porsche do sensibly install a generic wiring system which is tweaked to the model etc but it should save anyone needing to remove the list from the fusebox, should anyone find any errors ( this is the 07 model and so there may be other changes for other years ) please let me know.
Row A
F1 Power Window Left Door TRM30
F2 Central Locking Left Door TRM30
F3 Rear Control Unit TRM30
Rear Spoiler
Rear Lid Release
Two-Tone Horns
F4 Power Window Right Door TRM30
F5 Central Locking Right Door TRM30
F6 Rear Control Unit TRM30
Left Tail Light
Brake Light
F7 Rear Control Unit TRM30
Right Tail Light
Rear Fog Light
F8 12V Sockets
F9 Rear Window Heater
F10 Cigarette Lighter
Row B
F1 Instrument Cluster TRM30
Weight Detection TRM30
Diagnostic Socket TRM30
F2 Passenger Compartment Sensor
F3 Seat Adjustment Control Unit TRM30
Memory Control Unit
Combination Steering Column Module TRM30
Tyre Pressure Monitoring Control Unit TRM30
Alarm Siren
Sportchrono
Tilt Sensor
F4 Headlight Washer system
F5 Unused
F6 Vehicle Electrical System Control Unit TRM30
Filler Flap Release
F7 Unused
F8 Tiptronic Control Unit T30
F9 Telephone TRM86S
F10 Heating Klimatronic TRM30
Row C
F1 Unused
F2 Diagnostic Socket TRM15
Klimatronic Control Unit TRM15
PASM Control Unit TRM15
Refrigerant Pressure Sensor TRM15
Clutch Switch
Electronics Box, Mobile Phone TRM15
Heated Spray Jets
F3 Front End Control Unit TRM15
Light Switch TRM15
F4 Brake Light Switch
F5 Tiptronic Control Unit TRM15
Tiptronic Position Switch TRM15
F6 Rear Window Wiper
Non-Dazzle Interior Mirror TRM15
Park Assist Control Unit TRM15
F7 Combination Steering Column Module TRM15
F8 PSM Control Unit
Sensor Cluster
Key Module TRM15
Row D
F1 Fuel Pump
F2 Unused
F3 DME Control Unit TRM30
F4 Unused
F5 DME Control Unit TRM87
DMTL Valve
Secondary Air Pump Relay
Engine Compartment Fan Relay
Camshaft Adjuster
Camshaft Sensor
Intake Pipe Changeover Valve
Tank Vent Valve
Hot Film Mass Air flow Sensor
Air Conditioner Compressor Relay
Tiptronic Valve
Valve Lift Control
F6 Oxygen Sensor/Heating ahead of Catalytic Converter
Oxygen Sensor/Heating behind of Catalytic Converter
F7 Ignition Coils
Injection Valves
F9 PASM Control Unit TRM30
F8 DME Control Unit TRM87
F10 PSM Control Unit
F9 Electronics Box, Mobile Phone TRM30
DVD Player TRM30
PCM 2.1 TRM30
Telephone TRM30
CD Autochanger TRM30
F10 ASK Amplifier TRM30
Bose Amplifier TRM30
Bose Subwoofer TRM30
Row E
E1 Seat Adjustment, Left
Seat Memory Motors Left
E2 Seat Adjustment, Right
Seat Memory Motors Right
E3 Unused
E4 Unused
post edited by Buddy - 2017/08/28 18:26:11
Attached Image(s)
Kevan
Cayman Register Secretary
Location South Derbyshire
PCGB R8
17 Replies Related Threads
    • Status: online
    Guest Guest of the Club
    RE: Cayman S 2007 Fuse Listing 2014/10/14 15:28:14 (permalink)
    This really helped, thanks!
    A penny got caught in the cig lighter and I got a zap when I tried to remove it with a pen... all fixed now.
    Cheers!
    Mark :)
    • Status: online
    Re: Cayman S 2007 Fuse Listing 2015/07/27 23:29:24 (permalink)
    Thanks!
    I just had some crazy problems with CDR24... and the amp.
    The speakers were creating low thumping sound with lots of static - like they were possessed. Rattling the doors and sounding like the speakers were going to blow.
    Not sure if its the amp or the stereo yet, but pulling the fuse for the CDR seems to have shut down the sound output at least.
    Anyone have experience with a similar amp or stereo problem?
    2007 Cayman S - original equipment stereo - not the Bose unit.
    • Status: online
    Re: Cayman S 2007 Fuse Listing 2015/08/24 05:03:05 (permalink)
    When locking,red lights in doors ,stay on for ten secs, then rapid flash for ten secs,
    interior NOT AUDIBLY ALARMED !!??
    Buddy
    Buddy PCGB Member
    Re: Cayman S 2007 Fuse Listing 2015/08/24 07:01:41 (permalink)
    Problem could possibly be in the Amp, if you have the Porsche Package Plus stereo this amp is an obscure make and has problems, there is a place to send them but I don't know where, Alan Armstrong had a similar problem on his Cayman
    Kevan
    PCGB R8
    • Status: online
    Re: Cayman S 2007 Fuse Listing 2016/07/03 03:02:57 (permalink)
    Just bought a 2007 Cayman S and the third day in I am having the same stereo problem. I have the Bose package. Back to the dealer we go.
    Motorhead
    Motorhead PCGB Member
    Re: Cayman S 2007 Fuse Listing 2016/07/03 11:37:27 (permalink)
    Just to say that I think the known ASK amp problem referred to by Kevan only applies to the Porsche Sound Package Plus stereo package and not the Bose package.
    Alan Armstrong had his unit repaired by a chap in Norway ( http://www.bergvillfx.com ).
    987.2 Cayman S
    North Bedfordshire
    PCGB R10 and R24
    • Status: online
    Re: Cayman S 2007 Fuse Listing 2016/07/26 20:49:31 (permalink)
    Got the same problem on the amp. Porsche dealer advices to buy a new amp. Anyone aware of aftermarket resellers?
    edwin
    • Status: online
    Re: Cayman S 2007 Fuse Listing 2017/04/20 06:15:19 (permalink)
    Hi guys
    Could any of you tell me where the position of the relay is for the head light washers on a boxster 987 every one talks about fuses pump or blocked pipes but not about relays I have change the pump and fuse ok but stil not working
    • Status: online
    Re: Cayman S 2007 Fuse Listing 2017/06/08 15:41:34 (permalink)
    Thanks!
    Ive just had this same problem ... what was the outcome of your issue ???
    • Status: online
    Do you know which fuse covers the airbag warming light, I have a cayman S 2006 2017/07/17 22:58:54 (permalink)
    Does anyone know which fuse covers the airbag warning light and the type
    on a 2006 Cayman S please?
    Buddy
    Buddy PCGB Member
    Re: Do you know which fuse covers the airbag warming light, I have a cayman S 2006 2017/07/23 23:49:21 (permalink)
    You will need someone with a PIWIS computer readout unit, they will then be able to wipe the code and if it returns there is a definite fault.
    Kevan
    PCGB R8
    Buddy
    Buddy PCGB Member
    Re: Cayman S 2007 Fuse Listing 2017/07/23 23:50:40 (permalink)
    Sounds like a problem with the amp, go to an auto electrician
    Kevan
    PCGB R8
    • Status: online
    Re: Cayman S 2007 Fuse Listing 2017/09/09 05:45:28 (permalink)
    Thanks!
    I have just found the same problem, mine is on a 2008 2.7. Its the standard stereo. I will try the same as you have done and get back.
    Thanks Jimmy
    Motorhead
    Re: Cayman S 2007 Fuse Listing 2017/09/09 08:42:09 (permalink)
    As mentioned above, if you have the standard stereo with the Sound Package Plus option (code M490) Bervill F/X in Norway offer a repair service for the ASK amplifier.
    https://www.bergvillfx.com/index.php/services.html
    987.2 Cayman S
    North Bedfordshire
    PCGB R10 and R24
    corneg1
    corneg1 PCGB Member
    Re: Cayman S 2007 Fuse Listing 2018/06/17 15:40:15 (permalink)
    hi - anyone know the fuse for windscreen washers? Wiper are working but cant hear the washers.
    Graham
    corneg1
    corneg1 PCGB Member
    Re: Cayman S 2007 Fuse Listing 2018/06/17 17:36:56 (permalink)
    Hello
    OK - I located the fuse and its good. No washer pump noise so I am assuming its given up. Any advise on how to replace please?
    Many thanks
    Graham
    Buddy
    Buddy PCGB Member
    Re: Cayman S 2007 Fuse Listing 2018/07/03 13:42:12 (permalink)
    Looking at the PET Diagrams, there are two differing pictures for the 987, I would say remove the arch liner in the front left wing, then you should be able to get at the tank, the only picture is from the outside and there is one visible fastener for the tank in the picture and that is at the top going vertically upward into a fixing inside the wing from what can be seen! But the pump appears to be on the back inside corner of the tank from '08 and the other rear corner on the earlier cars, quite low down of course and pulls out vertically in both cases, whether there is anything to secure it other than the grommet isn't shown.
    As far as I can see you will probably need to remove the filler neck first which is in the plastic moulding inside the plenum area inboard of the wing so remove the cap and moulding, there is a flap to the rear of this covering the cabin filter. But I think the filler just pulls out of the bottle horizontally. On the later picture there appears to be a moulding which probably clips into the wing inner panel. It may be worth you checking if there is anything in the tank if it hasn't worked for some time, even syphoning it out as it has a large capacity to get in your lap as you lift it clear! Always possible that you have a broken connection, or even column switch.
    If you wish to get a copy of the PET Diagram it can be found, after some ferreting through the Porsche Website go to servicing and it's somewhere to be found by going through their lists and select a free download.
    post edited by Buddy - 2018/07/03 14:37:24
    Kevan
    PCGB R8
    Porsche
    Lockton
    Silverstone Auctions
    Pirelli
    Pirelli
    Oracle Finance
    Archant Dialogue
    HFMC Wealth
    Cornbury House
    Cotswold Business Village
    London Road
    Moreton-in-Marsh
    Gloucestershire  GL56 0JQ
    Call us: 01608 652 911
