Hot!986 Boxster coolant leak
johnc106
johnc106 PCGB Member
2023/09/30 16:15:11 (permalink)
My 986 Boxster lost all its coolant after a 45min drive. It seems to have come from the area under the coolant tank. I re-filled the tank and it held its level. I started the car and let it idle up to temp, and again it held its level. When I drove the car it lost coolant again.
Has anyone experienced this or have any clues please.
CLIFFWILKINS
CLIFFWILKINS PCGB Member
Re: 986 Boxster coolant leak 2023/10/01 08:31:55 (permalink)
Try a new coolant cap. first cheap option to try.
But sounds like if its leaking under the tank it's a new tank.
Good luck
post edited by CLIFFWILKINS - 2023/10/01 08:33:38
Assistant Register Secretary
Following: @BoxsterRegister
Current cars
Cayman R Peridot
Boxster 981 GTS White
Previous
GT3 Mk 2
GT3 Mk 1 S/Y Missed
Cayman Sport Viper Green
996 4S
4 986 Boxsters
987 Boxster
3.2 Carrerra
944 &924
johnc106
Re: 986 Boxster coolant leak 2023/10/01 09:17:48 (permalink)
Hi Cliff
Thanks for your help.
I tried a new cap and the problem is still there. Sounds like a new tank is in order 🙁
CLIFFWILKINS
Re: 986 Boxster coolant leak 2023/10/01 10:38:20 (permalink)
Yeah afraid so.
Best of luck with the fix.
Current cars
Cayman R Peridot
Previous
GT3 Mk 2
GT3 Mk 1 S/Y Missed
996 4S
4 986 Boxsters
987 Boxster
3.2 Carrerra
944 &924
Motorhead
Motorhead PCGB Member
Re: 986 Boxster coolant leak 2023/10/01 12:38:26 (permalink)
Hi Jonathon,
Before you go to the expense of replacing the expansion tank I’d be inclined to run a pressure test to ensure that it’s the tank that’s leaking and not just pipe in that area. Any competent garage should be able to do this for you at minimum cost.
It’s rather odd that you only lose the coolant when driving the car rather than at idle, which would indicate maybe that it’s a flow [pump-related] rather than a temperature issue?
987.2 Cayman S
North Beds (R10 & R24)
johnc106
Re: 986 Boxster coolant leak 2023/10/01 16:11:29 (permalink)
Hi Jeff
Thanks, will do. The engine temp is always normal which is strange.
I am going to ask the guys at Autostore to check it out for me.
I will post when it’s fixed for info.
johnc106
Re: 986 Boxster coolant leak 2023/11/05 20:41:44 (permalink)
It took some time to get the car looked at, and they found a fracture in the water pipe. Hopefully now fixed 👍
