Cayenne - Passenger Footwell Leak
I have developed a water leak in the passenger footwell which, I understand could be due to a blocked scuttle panel drain or a HVAC problem? I also wondered whether it may be related to the rear wash wipe which is not discharging screen wash?
Does anyone have any experience of this issue and whether it is easy to resolve?
Not sure what model you have but found a fair bit on you tube for my early car (which also has a panoramic roof). Would think if it was screen wash you would have a screen wash smell accompanying the dampness. The scuttle drains on mine (2005 V6) were behind the front wheel arch liners. I had drains that pass through from the interior behind the dash but they were all sunroof related as far as I can remember. Leaks can be a pain and sometimes even form the rear they can run under the insulation and make the front wet.
Scuttle does collect leaves etc though so a good place to start!
Good luck,
Tony
