Hi, last summer I had my oil changed as part of the normal service, my 981 doesn’t have a dipstick and I think the garage did overfill it. However the warning of overfill came on whilst in the garage and the took some out and all was good. A month or so later on my way home from Le Mans in June the warning of too much oil came on, I stopped turned off and when restarted the warning was gone. The warning remained off until about a month later it came on and finally went off. Now 6 months later with no issue in that 6 months the warning came on again. After a wait and a restart there is no warning and if you check it says the level is correct.
So if I am now an oil producer I should join OPEC, but more likely the sensor is at fault. Has anyone had this issue or has any advice.
