Good morning,
I’m replacing my PCM. I’ve removed the horseshoe surround to access the 4 retainers with angled Allen key. However PO seems to have fiddled with a couple of the retainers dropped out of place. I don’t want to damage the PCM as I will keep with car for any future sale (which I’m not planning anytime soon!) so still need to find a way of getting it out intact. I’ve removed the four torx screws on plastic chassis behind the horseshoe but nothing budges. I saw a video suggesting there are more torx at the back of chassis (beside the rear of the PCM). Is this the case and if so, removing those will I be able to remove the whole plastic chassis, with double din PCM in place, vents and cup holder above…all in one go? I’m a relative newbie to the 996 (certainly doing any work on it) so all help gratefully received. Thank you so much.
