Hot!Air Suspension Issue - 2011 Cayenne
Captain-Hastings
Captain-Hastings Guest of the Club
2023/01/23 16:23:31 (permalink)
I have a 2011 Cayenne 3.0 with Air Suspension.
Recently I have noticed that if the car has been standing for a day or so the offside suspension drops a little and continues to drop the longer it stands.
When the car is started you can feel the suspension levelling out and the car will drive normally.
Any ideas as to what may be the issue and does it need attention as long as it continues to right itself.
Thanks in advance.
Graham-S
Graham-S PCGB Member
Re: Air Suspension Issue - 2011 Cayenne 2023/01/24 07:35:52 (permalink)
Sounds like you have a small leak somewhere
Mine was the valve on the top of the bag. Found a VW part approx. £40 from memory and swapped it out, not more issues.
There are other possibilities like a pipe or the pump seal or the bag itself.
Needs a closer investigation
Hope that helps
Graham
R31
Current
993 Targa - Manual - Ocean Blue
60400 miles and climbing slowly!
Previous
2006 Cayenne 955 Turbo S - Salt Lake Grey as Daily Driver 123k
1982 Black Targa SC with 3.2 Carrera Engine
Captain-Hastings
Re: Air Suspension Issue - 2011 Cayenne 2023/01/24 09:53:25 (permalink)
Thanks Graham,
I guess I'll have to brace myself for a trip to the dealership to get it checked. - Always a scary (costly) experience!
Graham-S
Re: Air Suspension Issue - 2011 Cayenne 2023/01/24 12:07:25 (permalink)
Find a good Independent much cheaper. Where you based?
Graham
R31
Current
Previous
Captain-Hastings
Re: Air Suspension Issue - 2011 Cayenne 2023/01/24 18:22:31 (permalink)
Got a good independent who does my servicing and repairs usually, although he doesn't have the necessary equipment for this job unfortunately. (can't remember exactly what he said but I think it was to do with a pressurised tank or something similar)
I'll have to get it checked with Porsche and then possibly see if he can fit any necessary parts.
Thanks again.
