radial
Hey all,
I've got a weep / slow leak from the front side engine sump. This is the 3rd time I've had the same issue, in the same place. At least 2, maybe 3 times, before I have taken the sump cover off, cleaned it up, resealed it with the loctite stuff and torqued all the bolts in pattern to the required spec .. I think its 12nm.
Each time I get this slow leak at the front in the same place.
No evidence of a leak above the pan.
Any ideas?
Any ideas?
