Help Required - Gen 1 Jack Storage Tray
gpm993
Hi All
Does anyone know the Part No. for the jack polystyrene support tray for storage of jack within the boot well ............ my Porsche Centre doesn't know the part number
Many thanks
Thanks Andrew, however, that part is the toolkit storage tray.
I've recently purchased the spare wheel, toolkit, polystyrene toolkit storage tray (Item 15 in your diagram) and jack from my local OPC, however the Parts Debt weren't sure if the jack came with the storage tray ...... it didn't, and they are unsure of the part No.
Ideally, I need someone who has the part who could let me know the number so I can order - I don't want it rattling around in the boot well!!!!
Hi Clive
Just checked and that Part No. is the storage compartment for the compressor .... apparently!!
And I thought this would be easy, I know they exist as I've seen photos of the jack storage tray
Once again thank you for your response to my question
The tray for the compressor fits behind the LH felt side panel in the boot. It is a small square object about the size of a pocket camera and not at all the shape of item 20 in Andrew's exploded diagram. That is definitely jack shaped (see photo below) and carries the part number I quoted taken direct from Macan parts catalogue.
20 is described as "Toolbox Compressor" in the catalogue but that is what you need. [:)] You will also need: -
16. 95B 012 129 "Tool Holder"
21. 8R0 012 635 "Bracket for compressor"
22. 999 049 007 40 "Plastic Nut"
23. N 903 350 04 "Clamping washer"
Maybe the word "compressor" is wrong-footing you! [;)]
Hi Clive
Thanks for your post and I've now finally sorted it, it has taken some time but finally collected the part this morning. Why it didn't come with the ordered jack is beyond me because when you order the toolkit it comes with its own polystyrene storage tray!!
Jack polystyrene storage tray complete with Velcro securing strap, Part No. P95B 012 109.
For those requiring this part, you will also need the securing bracket, Part No. P95B 012 129
Thanks All for your help with this
Good news.
Pleased you were able to persuade your parts manager to look into it again. ????
