Helpful ReplyIntermittent Whistle noise.
davidmu
davidmu PCGB Member
2022/10/13 09:24:10 (permalink)
im new to 964s and am slowly getting to know my car. I am looking for some advice please. The car has been excellent and yesterday for the first time I noticed on start up an intermittent whistling sound from the rear. Any thoughts? Thanks for any input in advance.
mcgc0
mcgc0 PCGB Member
Re: Intermittent Whistle noise. 2022/10/13 09:35:39 (permalink)
Any more description? Whistling when - engine stationary idling, while driving etc? Able to take a quick video on your phone and post up?
'90 964 C4 Velvet Red
'94 968 Sport Gaurds Red
'90 964 C4 Slate Grey
'08 Golf Mk 5 GTi Black
PaulR964
PaulR964 PCGB Member
Re: Intermittent Whistle noise. 2022/10/13 09:44:47 (permalink) ☄ Helpfulby davidmu 2022/10/16 12:46:32
And is it triggered by something like the heater being on - which activates a blower at the rear?  Which in my case has been known to develop a squeaky bearing.
davidmu
davidmu PCGB Member
Re: Intermittent Whistle noise. 2022/10/13 09:49:05 (permalink)
Thanks for your reply, yes this only started when I put the heater on. The heater is off and I started the car this morning and the same intermittent whistle noise. Can I stop this, any advice? thank you
mcgc0
mcgc0 PCGB Member
Re: Intermittent Whistle noise. 2022/10/13 10:34:28 (permalink) ☄ Helpfulby davidmu 2022/10/16 12:46:23
As Paul suggests, maybe best to eliminate the rear blower as an issue first. With it on have a good listen to the fan motor, or better still check it out and feel for any fan rumble or wobble by hand. I changed the Bosch motor on mine as the shaft bearing had totally gone and had 'grooved' the housing. If the motor if fine maybe check the positioning of the heater duct tp fan shroud - with the fan on could that create a leak/gap whistle from a small gap between the two (and the rubber seal that joins them)?
Others may chime in
