944S camshaft wanted
jellytott
I thought and try my luck
After 2 used condition cam shaft for a 944S 16v standard fitment so not Race or S2 cams which fit but want to keep standard setup.
I have also posted it in the correct "Wanted" section but also here to reach out to 944 owners
John
If you don’t have any luck then call Newman Cams and see what they can make you. They’re pretty reasonable.
In my experience with them, they managed to make me an 8v camshaft (admittedly it has no gear wheel on it and you only need 1) for less than the price some U.K. specialists wanted for a regrind. Ironically - the specialist sent their cams to Newman for regrinds at a considerable mark up.
Have just called Newman Cams sadly don't do 944S cams so I'm sort of still on the hunt, but reconsidering my approach as sourcing good used cams is an issue so possibly I'm going to refurb my existing and not go down the path of rebuilding a second head now, so I'll keep the cylinder head minus cam shafts as a spare for a bit of future proofing the car too. Over time I can keep an eye out for them still to make a complete head.
