My 1985 911 3.2 Carrera is virtually ready for the road.
However it has developed a weird problem. I will only run on 5 cylinders!
It wont start.
The injectors have been replaced so its not a single injector. Its like the load of 6 cylinders is just to much.
But if you disconnect one cylinder it will start.
I doesn't seem to matter which injector you disconnect it will start. That seems to indicate its not the wiring or an injector.
I have ordered a dme relay as the easiest first step but I suppose if that doesn't fix it I need to look at the ECU.
Has anyone seen this before and if so what was the issue ?
It wont start.
