992 C4S Tyre pressures/TPM Settings - Comfort or Standard
DandyDon
Car is used mostly for spirited driving on A and B roads and some town driving. Not tracked nor will it be.
What setting do most have in TPM - "Comfort" or "Standard”? Is "Standard" the default setting for most?
Whichever you have why have you chosen that setting and what are the pros and cons of each?
I set mine to Standard when I got it 6 months ago. Now that I have done 5000+ miles all over the country it has lost 1-1.5 psi evenly at each wheel and I have concluded that I find it very comfortable … and am likely to leave it like that.
The actual comfort setting is about 5psi lower than Standard so I am kind of a little bit in the middle.
Mark
