How to find build date
- Thread starter V8rumbler
I used vinanalytics (www.vinanalytics.com) to get my build sheet. Very nicely formatted result and more readable than the output I got from OPC Makes a nice addition to the car file.
That sounds good - are you able to do a pic of what you get please ? Block your vin if concernedmalarcy said:Hi.
V8rumbler said:That sounds good - are you able to do a pic of what you get please ? Block your vin if concernedmalarcy said:Hi.
Attached - I redacted VIN and engine and gearbox serial numbers - otherwise it's as I got it - interesting one for me, is the Z options - the 09971 code - which is (factory special order) that tallies with the options listed in the sticker in the handbook - but never appeared on the info the seller got from the OPC - still not quote worked out which "exclusiv" option i got but it was good info.
Useful info here: https://www.stuttcars.com/porsche-boxster-2009-options-codes/
Thanks for that - just got mine -malarcy said:Oh and for some reason they couldn't "decode" option 555 - which is apparently black seat belts.
