Cayenne issues
stevehaley
this is on a 2016 diesel s
1. Just had a second headlamp washer fail with water dripping down the air dam underneath. First went at 40mths and now the other 18mths later. Is this usual?
2 the rear wiper has started to stall vertically and the only way to get it moving again is to pull the fuse wait a min then reinsert. Has anyone had this and what was the resilution
3. I am sure The 12v socket underneath the glovebox used to turn off after 20-30 mins But after the last service it now only turns off if the car is locked. This is a nuisance as it means i have to lock the car in the garage as the dashcam remains on and runs the battery down to the point where the car shuts it off.is my mind playing tricks.
Stephen
Hi Stephen
Mine is 2017 Diesel S but same version as yours.
No problems with headlamp washers or rear wiper. Don't know about the 12v socket - only use it when in the car.
Col
