My 2007 Boxster recently developed a fault whereby the car started mis-firing over approx 4500rpm and then dropped into limp mode.
The error code indicated a crank shaft sensor problem & this has now been replaced with a new Bosche sensor.
It didn't resolve the issue however & further investigations led to a new alternator being fitted.
I thought that had sorted it because the car drives perfectly but...over approx 6000rpm the problem returned.
The revs drop and the car judders as if its fuelled with kangaroo petrol.
If anyone has encountered this issue and/or can offer suggestions to rectify the problem I'd be very grateful.
Many thanks.
Many thanks.
