Panamera GTS 2013 all wheel drive occasional light on dash
GMX 1N
Hi guys, any info would be appreciated. Ive got the above 38k on the clock and the all wheel drive light has started coming on on most drives..... Turn off, start up again and it cures for 2 days sometimes..
Ive been doing some reading and they say this is quite a common fault if the rear battery is getting low (2013 so could do with replacing im guessing) as that battery regulates certain ecu's???
I found that info out on other sites, not this one, as ive just registered
Anyone else had this issue??
Its going for its usual frequent oil change and ive got my mechanic to change that battery and ill see what occurs..
Not Porsche man, but top tech at Audi..
Thanks very much....
If you are going to change the battery it has to be coded to the car if not it won't be getting the correct charging Rate
From justin
If battery doesn’t sort it , it may be prudent to get a diagnostics check for ABS wheel speed sensor faults given my recent experience ( see Hiccup with GTS in Apr 22 Porsche Post Panamera register column - should be available on-line via "news” section on club site if you haven’t got a copy )
