Cruise Control "unstable"
cobnut
Hi all. The cruise control on my 997.1 C2S is a little "unstable". Every now and again it'll simply disengage. Sometimes it'll come right back when triggered, other times it takes a few minutes/miles, sometimes it won't work again until the car is restarted. I thought it was simply an automatic disengage after rough roads (i.e. almost all the time round here!), but it's been doing it on relatively smooth surfaces as well.
Not a low speed issue, or anything else I can see any clues for. Seems completely random.
Any ideas? Are there automatic safeguards/checks that might be too sensitive or a failed sensor?
Jon
I'd be inclined to suspect the brake/clutch switches causing it to drop out.
They can get a bit worn or out of adjustment and cause similar circumstamces.
