I have waded through a number of threads but wanted to ask some advice as I think the car is acting peculiar.
Since having it in Nov 20, it has never had a start issue.
Drove it the other week, parked up and that was it (drive it a couple of times a week). 3 hours later, I went to move it and it wouldn't start. Cranks but doesn't catch.
I tested the fuel pump fuse as I have had this in the past on a 911. It was fine. So I put power to the fuel pump and it is working. SO I tried putting permanent power to the fuel pump and cranking it and it still wouldn't start. After fiddling for a while, I noticed that the interior lights were on but the headlights weren't working. So I decided to just jump start in a last ditch attempt and it works and fires right up. Drove it for a quick round the block, came back, parked up, put the battery on charge and left it.
Next day, full battery, no start again.
Checked the relay and with the casing open, I can see and hear it make the 2 clicks from the 2 solenoids.
When I put a test probe on the fuel pump now, with ignition, it is not on permanently but it does pulse power as the engine cranks over.
I wondered if anyone could advise before I start with the route of the crank sensors as this will be a pain for me to do on the driveway as I can't get it to the garage currently.
Could there be something else I am missing? Maybe something has just come disconnected.
It seemed to have literally just "happened" with no reason.
Thanks in advance.
Ben
Thanks in advance.
Ben
