Which CK charger?
My 991.2 GT3's footwell socket remains live for current draw when connected device is left in when ignition is turned off.
I used the C-Tek 5 charger in my 991.1
I normally just open the car, without having started the engine, plug the charger into the footwell cigarette lighter socket and then lock the car back up and it seems to work just fine (I leave the charger facing up so I can se the LED status without opening the car). Was working on someone else's car over Christmas and the RAC had fitted a C-Tek connector onto the battery with two wires bolted onto the battery terminating in a small connector with a rubber cap on the end to prevent water ingress when not in use if you're looking for a more permanent connection.
Best Regards
I use a CTEK MXS 5.0 which is designed to be suitable for AGM battery, charging monitoring and reconditioning. I connect positive to the battery terminal and the other clip to the REMOTE negative post. The max output of this charger is 5 amps, though if the battery is well charged it supplies a float charge which adjusts for expected voltage losses.
