Carbon fibre interior for 992 - retrofit recommendations?
RobertPoulten
Hello all, not sure if this is the right place to ask this sort of question so apologies if not, but here goes - I have a 2019 Carrera 2S 992. The only thing it doesn't have that I would like is some carbon fibre panels in the interior to replace the plastic ones. Porshe don't offer a retrofit on current models as I'm sure you know. I can't seem to find any options, does anyone have any recommendations for companies that would do this, at a price and quality which you know to be good? Many thanks for any steers. Robert Poulten
I believe there are companies that can coat your existing trims. They lay a layer of film in a water tank and pass the trim through it to transfer it on then lacquer it I believe. Looks good as well although you may want proper carbon fibre- expensive I would think!!!!
You would have to Google to find out more info.
Interesting, thanks. From Google there seems to be a couple of companies - DB Carbon and MA Carbon. Anyone have any experience of either?
