Length of wheel bolts cayenne 957
Ingemar
Good morning gents.
Going to replace my rusted wheel bolts on the 957 turbo with factory 21" Cayenne Sportplus Wheel with Wheel Arch Extension.Can you guyz tell me the length of the bolts?
Kindly/Ingemar
The bolt length is specified as the thread length (or shaft length). This is the measurement from the base of the rounded seat to the tip of the bolt. It is 35mm - 37mm on every Cayenne I have encountered. Unless you have spacers fitted, you should have this size, but worth removing one old bolt to check.
Are you buying OE Porsche bolts? You can get good quality non-OE ones for around £55. If you buy non OE, make sure they are grade 10.9 tensile strength.
